toedtoes
May 19, 2014Explorer III
I don't have a manual or a wiring diagram unfortunately. I can ask around as I know several people with 78s and 79s
You might try disconnecting the battery when you first turn off the engine after running it a while, then reconnect it and try starting it. If it starts, then you most likely just have something pulling battery power and the battery itself is OK. If it doesn't, then the battery is at least part of the problem.
