dougrainer
Oct 06, 2020Nomad
The LOP switch is located behind the Metal Cylinder head cover(That has the oil Filter hole) on the front of the Onan. There should be 3 or 4 small bolts that hold that cover ON. Also, inside the square metal box that has the Fuses and Start/Stop switch, you will see 2 square BOSCH relays mounted to the bottom of that box floor. Make sure you do NOT have ants inside those relay's. VERY common for the old Onans to get those ants inside those relay's. You will see dead ants all around those relay's if you have these ants. Doug
38,782 PostsLatest Activity: Sep 10, 2026
