dougrainer
Oct 07, 2020Nomad
ksg5000 wrote:
All the above comments seems reasonable. No generator guru but when you press the starter switch the generator essentially bi-passes the hi tech safety stuff and the generator fires up. When you release the button then all the electronic safety stuff engages. Loose wiring and low oil are the two inexpensive solutions.
Yes, but OLD Onan Gensets do not have "any electronic" control parts at all. They do not even have a electric starter in the type of new Onans or cars. Even the Older CCK Onans, that had electronic control board, it was replaced with the old mechanical systems which is what the OP has. Doug
38,782 PostsLatest Activity: Sep 10, 2026
