dougrainer
Oct 07, 2020Nomad
MrWizard wrote:
Doug is right
It uses a winding in the generator head to act like a starter, spin the generator armature shaft to slow crank the engine for starting
Has points and ignition coil, no CDI,
Thermal choke, and battery charging to keep the generator start battery charged,
Many of these were wired to the chassis battery when installed, not the RV house batteries,
Since they supplied a charge to keep the battery up, they would charge the engine/chassis battery,
And the RV converter would charge the house batteries
The battery charger was a 1.5 amp. You had DC and AC brushes on the very large Armature. DC brushes are what turned the armature and the engine to start the Genset. Once running the AC brushes supplied the AC current. Doug
38,782 PostsLatest Activity: Sep 10, 2026
