Buckmeister420
May 01, 2022Explorer
Rick Jay wrote:
Buckmeister420,
Welcome to the Forums and good luck with the project.
Do you have covered storage for this RV? If so, the roof condition probably isn't too important at this point. But if not, I would seriously consider making sure the roof was solid and water tight to prevent any water damage (or any further water damage) if there are leaks. I'm guessing that if the rig just sat, and no one has tended to roof in quite some time, there could be issues.
I know you're focused on the engine, but in my opinion, the roof condition and any water leaks would be the FIRST thing I'd be concerned about.
Again, Welcome and Good Luck!
~Rick
I do not have covered storage and it’s funny you say that because that is exactly what someone else said. Go around and seal every little thing I can seal and fasten all I can fasten. Make sure it isn’t leaking.
Good news: I got it to fire up today with some starting fluid. Died after a moment. Found out it has 0 gas in the tank, topped it off with 2.5 gallons. Nothing but it did fire a second time with starting fluid.
I removed the supply line for the fuel. Nada. No fuel so now next is just figuring out which fuel pump is bad, or if it’s all of them, or if it’s a relay. Could be anything.
Going to go to the store and get some testing equipment and some more tools, and I’m going to go to town on this fuel system. I realize it could be something as simple as a clogged filter - but I don’t hear anything as far as a buzz or hum when I turn the key.
I’m thinking to document everything I do with pictures and then put it all together when I’m done. I was impressed with the website someone else put together. Thanks for all the advice.
38,782 PostsLatest Activity: Sep 10, 2026
