- DaveinetExplorerI just bought a standard short one from a speed shop and pull the engine cover when I need to check the oil, because the fill is under the cover as well. This engine is designed to consume oil, so I'm usually topping it off every time I check it.
- Argosy24ExplorerWhat's wrong with it? Broken or cracked it can be welded or brazed.
Also check online for RV salvage yards. - C350amgExplorerJust changed mine on a 454 vortec P30 chassis.
Had to get it from workhorse 125$
MH deep stick are much longer than truck versions. - What chassis? Ford, Chevy, etc.
Could try www.rockauto.com - mobilefleetExplorertake it off and take it up to NAPA. They carry lots of parts for med and heavy duty chassis and can match it up
38,782 PostsLatest Activity: Aug 23, 2026
