Daveinet
Dec 02, 2013Explorer
As far as heat, with a proper muffler - meaning straight through, you should have considerably less heat than with manifolds. The engine does not work as hard to pump all that air out the exhaust, which translates into considerably less heat.
While I understand the motivation for cheap, the one issue that will be hurt with cheap headers is noise. Cheap means thin wall pipe, which then radiates more noise than manifolds or thicker headers. Even Banks are which are thicker than cheapo, but still thin, radiate more noise than manifolds. Thorleys are thicker pipe, so they have less noise, and by experience, make less noise than standard manifolds at cruise. H or X pipe will also reduce noise and of course help low end performance). Generally speaking, a Tri-Y has a broader power band, so it is more suitable for RV use than 4 into 1.
