1995brave
Jul 27, 2023Nomad
Is your fresh water tank metal? If it is it probably pressurized with about 30 psi of air. Unless it was converted to a 12 volt water pump. It it's a plastic tank you have a 12 volt pump. Do you have a house battery or converter? Plug it into 120 ac and see if you have a switch somewhere that says pump or water pump.
