turbojimmy
May 29, 2015Explorer
Have you checked to see if you have fuel at the carb by cranking it with the fuel line unhooked?
The rubber lines at the tank may have rotted out and are not allowing the pump to draw fuel from the tank (it needs a vacuum). Happened to my '84 P30. I had to replace all the rubber lines.
38,780 PostsLatest Activity: Nov 22, 2015
