Wes_Tausend
May 31, 2015Explorer
Ryan,
If the engine won't idle, a common cause is that carburator idle jets are plugged. The obstruction can come from debris from deteriorating hoses, rusting fuel tanks (condensation in stored less-than-full tanks) and quite frequently, vehicles parked so long the carb dries out, leaving sand-like fuel deposits that break loose after restarting.
In 1978, automobile carbs already started using smaller idle jets to lean idle mix down and reduce raw fuel emissions during idle. Idle was one of the worst pollution offenders on older cars because idle was set very rich to assure that some fuel vapor mist made it as far as the cylinders after traveling a long path through the intake runners. Much of the fuel stuck to the walls and simply dribbled into cylinders where, unburned, it eventually pumped into exhaust and came out as stinky vapor. Unfortunately the new smaller idle jets plug up with much smaller particles. Such an engine is hard to start and will only run at medium to high speeds where the huge main jets began to supply some fuel. This is especially true of new small engines like motorcycles and lawnmowers which have the tiniest idle jets imaginable and, yes, the final mix is still a bit too lean since it is missing the idle jet contribution.
Whew. All that said, your problem is probably an idle failure after a hard pull. This can happen because the fuel bowl finally runs so low on fuel (drains) that the idle jets are uncovered. The reasoning is that the carb starts up the hill just fine at low fuel/power requirements because the marginal fuel supply system can still meet demand and the carb fuel bowl is still full. As the vehicle climbs, the fuel requirement begans to outpace the worn pump's ability to keep up. The bowl slowly loses ground, graduallly decreasing power, until the fuel mix becomes so lean the engine will not even run.
By the time you read this, it is likely you have already largely fixed an insufficient fuel supply problem. But other problems may arise from lack-of-use debris and rotted hoses, perhaps the cause of fuel pump failure.
Plugged idle jets can some times be unclogged by spraying WD-40 backwards through the idle air adjustment screws. Use the tube attachment directly into the threaded hole to gain the most pressure. Do not use aerosol brake cleaner, aerosol carb cleaner or any other harsh solvent. Gently bottom the screws out first and count the turn setting making careful note to return them to exactly the original setting where they will again work best when all is clean. Remove the screws and spray away. This is easier than disassembling the entire carb and works particularily well in small engines.
You can try simply blowing backwards through the fuel line to the tank to see if it is plugged. It should gurgle if the tank has any fuel in it.
Good luck.
Wes
Good luck.
Wes
38,780 PostsLatest Activity: Nov 22, 2015
