turbojimmy
Jun 21, 2015Explorer
tropical36 wrote:Ryan7361 wrote:
Time for an update! So my electric fuel pump is shot. To test it, I found the fuel pump relay and put 12v on the pump lead(i heard a noise at the tank). I took apart the fuel line at the inline filter(by right front wheel) and nothing was coming out! So either my pump is shot or the in-tank filter is totally blocked, right? I am NOT looking forward to dropping my tank..........
Ryan
Before dropping the fuel tank for any reason and should it ever become necessary, first check and see if a hole can be made through the floor above and then a marine type access plate installed.
This is what I did. Knowing (hoping) that I shouldn't have to do the job again, I put plywood back over the hole and new flooring over top.
38,780 PostsLatest Activity: Nov 22, 2015
