Ryan7361's avatar
Ryan7361
1987 Establishment P30 starts but dies in idle
I have a 1987 Establishment P30. It will start and run, but as soon as I take my foot off the gas it stalls out. It started during a trip when I began to lose power going up a hill. Things got better after the hill, but 2 or 3 hills later we stalled on the side of the road and had to be towed home. It's a chevy 454
I've replaced all the:
-fuel filters
-and put in a new mechanical fuel pump.
-sprayed "gum out" into the carburetor
Any ideas for an Austin area mobile mechanic?
Ryan
  • Check the electric fuel pump that is located by the right rear tire. It gets the fuel to the mechanical fuel pump. rubber fuel lines might be a problem, but that would show up more when you are stepping on the gas than dying at idle. Mine acted the way you are describing but that was after a complete rebuild of the carb and no fine tuning was done when it was installed.
    One FYI I always add Lucas fuel treatment to our MH, 1 cup for every 10 gallons of gas. It is expensive, but not having fuel problems makes it worth it to me.
  • Have you checked to see if you have fuel at the carb by cranking it with the fuel line unhooked?
    The rubber lines at the tank may have rotted out and are not allowing the pump to draw fuel from the tank (it needs a vacuum). Happened to my '84 P30. I had to replace all the rubber lines.
  • rubber vacuum advance lines are collapsing is my first guess. Replace them. Notorious problem with them as they age. $10.00 BUCKS OF RUBBER HOSE WORTH A TRY.
    Not mobile but try Fleet Maintenance of Texas
    4800 E 7th Street, Austin, TX 78723
