kerrlakeRoo
May 28, 2017Explorer
First thing to check is usually the ground. Quick and dirty, try a jumper cable , bat negative to a good ground point see how it does then. Since you seem to be having whole system problem with voltage, corrosion on the ground strap would be the first suspect.
38,781 PostsLatest Activity: Aug 12, 2026
