coachellacanuck's avatar
Feb 21, 2018
1988 Ford Lazy Daze with 97 km: too old?
We are snowbirds in need of an inexpensive Class C to make the trip between Alberta and California, south in October and north in May.
Came across this one and here is what I know about it from the Craigslist listing.
26 ft long
V8 5.7 L engine.
Automatic
•replaced the front tires and two back tires
•installed a new brake hardware kit
•replaced the valve system
•rebuilt the tire pressure monitoring system
•balanced the wheel spin
•installed a new water pump
•new starter with life time warranty
It’s $3000.
The current owner is the third owner and bought it to remodel so the flooring and furniture has been removed which is ok by us because we want to remodel as a mobile office.
I have to think it will get about 10 miles per gallon. How does that compare to newer Class Cs, do you think?
I would have it inspected mechanically but I’m wondering what problems these units may be known for?
As always, thanks in advance for any advice
    26 ft long
    V8 5.7 L engine.
    Automatic
    I don't know where you plan to stay in California. Many urban areas are currently experiencing a very high volume of older RV's parked on public roadways which are being used as housing for the homeless. (they really aren't homeless if you consider your RV as your home temporary or not) That said, those RV's that appear to be in less than pristine condition tend to quickly attract the attention of local law enforcement. If you plan on staying in higher end RV parks you may have issues with the "10 year rule" if your vehicle doesn't appear to be well cared for. If you plan to boon dock at BLM sites or other less regulated open land, you may avoid most of the above issues.
    Chum lee
  • We bought one last aug, was not a bad price, and the owner had brought it to a local Ford dealer to have the safety check done about a year before we picked it up, from what i could see was that it had all the brakes re done, new flex hoses, 6 new tires, hanger bearing and u joint..
    so i figured it wouldn't be too bad.. had it re safetied to put in in our name with no problem other than having to fix clearance lights and tail light, (normal issues), had it out a couple of times and then found we had major rot to deal with... still in the process of fixing all that now, but it coming along slowly,
    hoping to have it all back together for may... ours btw only have 52,000 miles with a ford 460ci
