Britches
Aug 13, 2014Explorer
I think we got this licked took the pump out and this is the one that did not run 5 minutes. The terminals on the pump showed a green/white corrosion which is a short, most often. I found that the power (Hot lead and ground) were rubbing inside on the under side of the lid and the power ground was going to the sending side and A make shift short wire hooked around a lose nut. I removed the pump and hooked to battery and pump no good. I had a spare pump for testing hooked it up to battery and proper ground and son of a buck took off. So $202.00 later new hanger wiring the whole deal for inside tank and new 3 pin terminal will install tomorrow and boy I hope this is the end of this mystery. One little worry is the pump is a max 17 psi min. is 4 psi so could have to drop tank again if to high of pressure, but worth a try
38,773 PostsLatest Activity: Apr 24, 2026
