Britches
Aug 14, 2014Explorer
OK input is good J-D. Wiring now I changed ok here goes. Battery neg. ground wire connected to wire coming from neg. Connected on to ground at fuel relay about 7" spliced in ground wire to screw on motorhome. checked and solid ground.
Next checked to make sure that instrument cluster that the orange turn in to green connected and ground is true. Next I will install new wired hanger and new pump and will connect plug to pins. secure tank and all. I am putting 10 gals. gas in, just insure no foul up. next message will tell whether all if repaired or not. One thing I will say. Any one that is repairing wiring in a auto or house, take the time to incorporate color code, the next owner will praise your name.
38,773 PostsLatest Activity: Apr 24, 2026
