- Cousin_Eddie93ExplorerAlso the tank may be contaminated. Make sure there's no particulates, paint chips, plastic shavings, or other debris that could be clogging up all those new pumps.
Edit on the water pump, way too little sleep last night. - woodgeezerExplorerHave you flushed the lines? If there is crud stuck and blocking fuel, you may have a plugged line filter or the carb mounted filter. Make sure the fuel can flow freely.
38,773 PostsLatest Activity: Apr 25, 2026
