Replacement fridge for your unit should be this item. I have the same year make and model owned since new and eventually had to replace the 3 way fridge. Three way means having propane 12volt and 120 volt options. The original unit installed by Xplorer was RM 2333 now it is with upgrages Dometic RV Replacement unit RM2354 ..3-way pwr manual controls..same as our RM2333 for dimensions. Only difference is the controls are on top rather then the bottom and are electronic. Otherwise it is a drop in fit. It can be ordered via any RV dealer or repair service that has an account with Dometic. I put mine in myself. Had to take out the passenger seat to allow removal from within the RV interior. Time consuming but very do-able all alone along with copious amount of cuss words. Write if you want more info.
