JKFlipFlop
Aug 15, 2015Explorer
1989 Dodge Xplorer
Guys I dropped 5,500 on this beast. It has 55k miles, new tires, new AC in back and front. Everything but refrigerator works. Onan 2800 gen works. Did I pay too much?
chainegang wrote:
Replacement fridge for your unit should be this item. I have the same year make and model owned since new and eventually had to replace the 3 way fridge. Three way means having propane 12volt and 120 volt options. The original unit installed by Xplorer was RM 2333 now it is with upgrages Dometic RV Replacement unit RM2354 ..3-way pwr manual controls..same as our RM2333 for dimensions. Only difference is the controls are on top rather then the bottom and are electronic. Otherwise it is a drop in fit. It can be ordered via any RV dealer or repair service that has an account with Dometic. I put mine in myself. Had to take out the passenger seat to allow removal from within the RV interior. Time consuming but very do-able all alone along with copious amount of cuss words. Write if you want more info.
