drsolo
Dec 19, 2013Nomad
Econoline424 wrote:
I recently purchased a 1989 Econoline Conversion van (75K mi)
the temp gauge moves toward the "High" mark as soon as the van is warmed up.
mechanic who said it was likely one or combination of radiator, thermostat, water pump. $1200 - $1500 to fix all three. Right now, I don't have much confidence that the van could withstand the rigors of a long distant trip.
The thermostat was changed in August by the previous owner.
Also, after shutting off the van at one point, and restarting the engine, the temp needle moved all the way to the High point, but then came back down to slightly above Normal.
Any suggestions? Do you experienced folks think this is a radiator/water pump problem?
I got a 1992 GMC in 2011. I told my "former" mechanics to go over it, bring it up to "long distance capable". Well, they didnt. The brake fluid was dirt. There was almost no oil. The radiator cap was frozen on. I got a new mechanic that knows his stuff. And you need a good mechanic to go over the whole van with a fine toothed comb and tell you what is the problem and what needs to be done. These older vans can go well over 200k miles, but older also means seals, hoses and belts are old as well and need to be replaced. I came up with a quick check list (before I leave on trips) in addition to anything I want him to repair.
check water in battery, clean terminals, check wires to starter etc.
check condition of tires and air pressure
check brakes and fluid
check oil, replace fluid and filter if oil is dirty
check transmission fluid
check belts for wear and replace worn
check hoses for wear and replace worn
check headlights, brake and signal lights
grease whatever needs to be greased on suspension, etc.
My radiator was overheating. I had an "intermittent" leak when the van sat around. He found the leak, a seal or a hose somewhere. Cheap fix. I had the oil gauge swinging wildly, had to replace some "sending" unit. Replace the thermostat. Even new ones can be "bad", it is a cheap fix if that is what it is.
