hram's avatar
hram
1989 Holiday Rambler Imperial no headlights
Hello all,
Driving down interstate and noticed no headlights. When I pull switch, I get full rinnigh lights and thats it. Replaced headlight switch, no change. Has aftermarket turn signal handle with cruise and low/brights pull switch. Has anybody had a similar problem and could help? Trying to get to badly damed hurricane property in Rockport, Tx so extra night driving hours would be greatly appreciated. Thanks! Greg
  • 30 year old coach, stuff such as turn signal aftermarket handle will need replacement. Even OME will.
  • If both headlamps are out on both low and high beam, it can be:
    The dimmer switch,
    The headlight switch, or
    The headlamp fuse that is very often a separate fuse in the chassis fuse block.
    Good luck.
    Matt
  • It could be any number of things.
    Bad relay to headlights,
    Bad low/bright switch
    very outside chance both lamps are bad.
    You need to trace it out
