blazenpm
Jun 18, 2015Explorer
I also have a 1989 Bounder that I have more or less restored. On your electrical issue. Check your inside breaker panel, make sure they are all on. Then if you feel confident, take a circuit breaker to check your fuses in that panel to make sure they are all functioning. You might want to also first check your house batteries condition and the cable connections for cleanliness (ie no corrosion etc.) and that they are tight and snug. If none of that works I suggest you take it to your local trusted RV repair shop. Hope my ideas work for you. Good luck.
38,771 PostsLatest Activity: Apr 15, 2026
