C-172-AV8R
Jun 25, 2015Explorer
What a PITA to check the fluid level. Mine is the same crank the wheel to the far left try to fit my hulking butt into the space ahead of the tire put hand into hole and release the two reservoir springs with a screwdriver. Cut the bottom off a water bottle to use to fill and dump into the reservoir which is on the inside of the frame. At least they left a hole in the frame to get my hand through. Try to get one eye high enough to see if fluid level is correct. Try to get the springs back where they belong and presto were done. See how easy that was. Now a hole in the drivers floor that would be just to luxurious. :)
38,768 PostsLatest Activity: Nov 21, 2015
