Raist11
Jun 27, 2015Explorer
Son of Norway wrote:
The Chevy chassis of my HR has similar problems with access to the master cylinder and reservoir. I measured out the location and cut an access hole in the floor right above the reservoir. I made a cover out of diamond plate with some insulation. The hole with the cover is right under the driver's floor mat so it is not even visible. It only took me a couple of hours and it dramatically increased my motivation to check my brake fluid on a regular basis, so it was well worth it.
Miles
I'm thinking that cutting a hole is best option. What did you use to cut the hole? I'm assuming I'd be looking at going through wood, then metal? I'm thinking maybe even just a 3" hole saw. I can get the cap from the side, then run a long funnel down through the hole to fill..
38,768 PostsLatest Activity: Nov 21, 2015
