Tim_Nowicki's avatar
Tim_Nowicki
1991 Pace Arrow owners.......Question
Anyone that has or did have a Pace arrow 1991 vintage, Chev chassis, couple questions.
If you have the 4 speed overdrive transmission are you seeing a dashboard light come on when in overdrive?? I have an overdrive light on my dash but I've never seen it come on.
Also are you seeing a drop in RPM when overdrive kicks in?? I'm at 3000 RPM and doing 55-60 MPH. thanks guys
  • I have no button for engageing the overdrive on this rig. I will have to check to see exactly what model transmission I have on this rig. It is a 454 TBI. Letters on shifter read as follows 1 - 2 - D and then D with a square around the D. I was assuming this was an overdrive transmission.
    I will check the model number on the trans, but in the mean time, anyone know what I may have here?? thanks
  • posibly a 91 on an earlier chasis. The 91 chasis was the first year with the 480LE trans.
  • Gjac's avatar
    Gjac
    Explorer III
    If you have the 454 TBI eng and the 4080LE transmission 2500 rpm at 65 is about normal. 3000 at 60 mph sounds high for a 4 speed transmission I don't have an overdrive light on the dash. Are you sure it is a 480LE trans? If it is a 3 speed then the rpms make sense.
  • I had a 91, let me see now. If I remember correctly, when you push the button on the shift lever, the od light comes on, but overdrive is locked out. 3000 thousnad and 55 sounds a little high
