77rollalong
Mar 11, 2018Explorer
if its breaking the half shaft, i would be checking the axle housing to make sure its not bent, as that would cause strain on the half shaft, and there is no weight on the half shaft only the torque, or the half shaft is over hardened, maybe have them try reversing the half shafts, and see if it breaks the same side again, if so then the axle is bent..
38,777 PostsLatest Activity: May 24, 2026
