- Yes seems odd. Was the replacement a used axle? Where did the break in the steel actually happen? Same place both times?
- RLS7201Explorer IIDiesel or gas? Ford or Chevy? Where is the axle breaking. We all know full floating axles don't carry any weight so it must be a twisting or bending force that's breaking the axle. Could it be the hub bearings are loose, allowing the hub to move? Or it might be a bent housing or spider gears not turning.
Richard - allbrandautoExplorerwhen installing the axle does it go in freely or do you have to beat in if you have to beat it in may be the diff. housing is bent
- DuctapeExplorerIs the diff working? Does it r resist turning and do you get tire scrubbing in corners ?
- Dale_TravelingExplorer IIHow much weight is on the axle?
38,766 PostsLatest Activity: Jan 10, 2026
