Mlequo
Oct 04, 2023Explorer
Thank you! I am missing this outside box with fuses and relays. In front I can see some basis push up fuses and solenoids, but no master fuse or anything like that.
Ava wrote:
I have a 94 Fleetwood Bounder DP. Mine has the outside box up front, interior fuses inside one of my upper cabinets and the I have another black panel in my battery compartment. Chassis related fuses are found in there. There are also battery relays in there. If you have a panel like that, I would bet the problem is in there.
I would assume they were wired similarly back then. Good luck
