way2roll
Sep 09, 2020Trailblazer
Starshipcommander wrote:
Thanks to all who weighed in. What does the gallery think of this? Beef up every system?
1. Go to slotted and cross drilled and ventilated brake rotors front and either convert the rear to disc or go to the next bigger size of drums.
2. Add say 25% more volume radiator
3. Beef up the Hitch to a 5 or better yet 10k
4. Install an oil cooler and transmission cooler
5. Lower the rear end ratio or replace the entire rear axle with something bigger, beefier and have a push button locking differential
6. Replace the fuel delivery system with state of the art in 2020 fuel injection
7. Replace stock exhaust with headers going into an oversized single pipe
I have so little money in this rig that I could add these improvements one at a time. Any comments on the ideas?
You didn't mention beefing up the frame. The stock extensions are rated at the current hitch. Your frame would need some re-engineering.
Playing devil's advocate, sounds like you spent very little money on this rig and that's fine. But even if you do every single upgrade - which by the way may still not work - it will add nothing to the value of the motor home. If you plan on keeping this a long time it's a moot point, but you won't get your money back out of it.
If it were me - and I understand I am not you - the money spent on all these upgrades that may still not work, could be spent on an RV already built that will work. Or a TOAD that this one can handle.
38,782 PostsLatest Activity: Sep 10, 2026
