timmac
Sep 09, 2020Explorer
Starshipcommander wrote:
Thanks to all who weighed in. What does the gallery think of this? Beef up every system?
1. Go to slotted and cross drilled and ventilated brake rotors front and either convert the rear to disc or go to the next bigger size of drums.
2. Add say 25% more volume radiator
3. Beef up the Hitch to a 5 or better yet 10k
4. Install an oil cooler and transmission cooler
5. Lower the rear end ratio or replace the entire rear axle with something bigger, beefier and have a push button locking differential
6. Replace the fuel delivery system with state of the art in 2020 fuel injection
7. Replace stock exhaust with headers going into an oversized single pipe
I have so little money in this rig that I could add these improvements one at a time. Any comments on the ideas?
Sell the motorhome if you already bought it and cut your losses, get a newer motorhome like 2000 or newer than you wont need improvements for towing 5000 pounds.
In 2006 Ford did lots of good improvements to the chassis, better motor and transmission, better cooling and radiator, better suspension and brakes and can tow 5000 pound..
38,782 PostsLatest Activity: Sep 10, 2026
