shelle007's avatar
shelle007
1995 Bounder and What to offer on it
We have a lead on a 1995 Bounder 34 J. It has 48,000 miles on it. It's been kept in a barn when not in use since the current owners bought it in 2005. It appears to be immaculate as far as I can see by pictures. The bad thing is it has the same tires as when this guy bought it from 2005 so they are in excess of 11 years old. Obviously those need replaced before I would consider even driving it the 3 hours back home. I am trying to decide what I would offer him if we go see it. He wants $11,900 which I think is too much since I have to spend $2,000 in new tires. I am thinking $8,000 would be more like it. Do you think it's going to offend him as a seller?
Here is what his ad says about the MH.
1995 Fleetwood Bounder 34 J - $11,900
Chevrolet chassis, 454 with Banks PowerPack, Upgraded Roadmaster Sway Bars, Bilstein Shocks and Steering Stabilizer, Hydraulic levelers, Front Air Leveler Bags, ONAN Marquis 7000 Generator (Will run both AC), New Coach 6V Batteries, Basement Water and Holding Tanks Enclosed and Heated, Extras include Water hoses and Filter, Sewer hoses with supports, Power cords and adapters, LP BBQ Grill, Tables, Safety equipment (Reflectors, Flares, Wheel Chocks, Jack, Lug Wrench), Lots of Basement Storage, Receiver Hitch with Wiring.Interior with CB Radio, Alpine AM/FM/CD Stereo, 2 LCD TVs, Washer/Dryer Combo, Queen Bed, Dual AC (Front has Heat also), Dual Furnaces, Dual Pane Windows, Roll-up Shades Throughout, 3 Burner Stove with Oven, Microwave, Gas/Electric Refrigerator, Water Filter with Dispenser, Lots of Storage/Closet Space, Power Roof Vent, Bath Vent, Extras include Flatware, Dinnerware, Glassware, Cookware, and Utensils. Monitor Panel, LP Gas Detector with Shutoff, Smoke Detector, CO2 Detector.Has been garaged. Well cared for. No history of full-Time Living. Non-Smokers. Clear Title, Current Registration, Current Insurance.Only selling due to health.
  • mike brez wrote:
    It has a P30 chassis. It was meant for potato chip delivery not rv. If your funds would allow I would look for a newer one on the WH chassis.
    do a search for issues with the P-30/32 chassis before you buy. front end very weak. headers go bad.
    bumpy
  • Just cause the tires are 11 years old you can still drive it home even if its 3 hours away, just drive slow and you should be OK.
  • It has been in the barn
    The tires are not exposed to the sun
    Should be OK, at least for the drive home
    Instead of three hours at 70mph
    Make it four hours at 55 mph, stop at the two hour half way point have a snak stretch your legs check the tires
    No need to rush
  • You want to make sure that you get all steel sidewall tires. These are either Michelin RIB tires, or Goodyear tires. Chances are that you will need to call a local tire dealer, and order them. I bought my last set of Michelin's at Wal Mart, and they took a week to arrive at the store. But you need to check to see if Wal Mart can install a 19.5" tire, that is found on the GM's.
    I had Michelin RIB tires, and replaced the front pair with Goodyear all steel tire, and the back set I bought some Goodyear Wrangler tires. Huge mistake, because those are polyester sidewall tires, and more flexible than the steel sidewall tires that I had to buy 500 miles later, to get rid of the flex in the rear tires.
    I found out at a FMCA show, where there was a Goodyear rep, and he showed me the difference. It turned out to be a fairly expensive mistake, but I was able to sell the tires with 500 miles on them to a friend for $100 each.
    I have a 1997 Bounder on a Ford chassis. So I have 16" rims, while the GM will have 19.5" rims.
    At least you will have tires that will be good for 30,000+ miles or 7 more years. Also let the tire dealer know that you will not accept tires over 1 year since date of manufacture. No need to lose a year of service because he found some old tires in the back of a warehouse.
    I only have one A/C because I am only 30' long. I don't recall if your model has slides or not? The non-slide models don't sell for a lot of money anymore. I wanted a non-slide model, because they where still working the bugs out of the slide system back in the mid-90's. I think they had it solved by 1996, but did not want to chance it. . .
    Fred.
