jgonzales11's avatar
jgonzales11
1995 Coachmen Santara with Ford F53
My alternator isn't sending power to the chassis battery--both are new. I'm thinking there's a blown fuse or issue with the fusible link.
I've only just begun, but thus far, I have not been able to find a diagram for this engine. If anyone knows where the fuse for the alternator is, please let me know.
Thanks!
Josh
  • None of the sensor lights in the dash are working either... could this issue be related?
  • voltage sense / regulation issue
    wrong Alternator ?
    bad voltage regulator ?
    if you read 12.2 at the alternator,
    then the alternator is connected to the battery ?
    the question is, why is it NOT turning on ?
    this is voltage sense circuit, voltage regulator, bad engine computer module ?
    what controls the voltage on a 95 FORD ?
  • Here is a F53 for the 1995 charging system.
    http://www.irv2.com/forums/f23/94-f53-fuel-pump-change-230973.html
  • with no sensor lights in the dash that's where you problem is it excites the alt. threw the dash light bulb for charging system if none of your warning lights in the dash are out check all your fuses in fuse box 12 volts comes out of ign. switch to fuse box to dash
