sjholt
Nov 19, 2014Explorer
Service Bulletin: Repeated Failures of New Fan Clutches
Multiple failures of New Fan Clutches on the same vehicle when the failure appears to be bearing, seal or shaft separation related should perform the following:
Closely inspect and replace the water pump if visible movement of the shaft in a vertical or horizontal direction is noted when checked by physically applying pressure to the fan blade in a front to back direction with the vehicle turned off and the battery disconnected.
