Does anyone know where the hot water tank shut off is on this Class C RV 1995 Minne Winne is there one ? I cannot not find it or do I just blow out the water for winterizing -------- Thanks
bypass is easy to install but will probably be a next year thing. Just remember not to use HIGH pressure on the water lines. As I said 40-50 lbs is fine
