enblethen
Aug 30, 2014Nomad
You can jumper pins A & B and read codes. The engine check light will flash the codes three times for each error. The check light doesn't have to be on to have codes.
Pins A & B are on the bottom of connector right side. Place jumper, turn on ignition and watch check light. 12 means it is checking, then codes.
38,768 PostsLatest Activity: Nov 21, 2015
