garry1p
May 24, 2015Explorer
Had the same problem was a bad gasket under the throttle body. Research showed this to be a problem that will throw a lot of codes.
One test is with the engine running spray some WD-40 at the base of the TB and the engine will speed up. That should not happen.
I think it was a $12 fix.
