I have a 1995 Georgie Boy Pursuit, 27', 454 TBI with front disc and rear drum brakes. Purchased the rig about 1 year ago and did a complete front end brake job: turned rotors, new ceramic pads, repack...
No, do not use wheel bearing grease. It should be brake caliper grease. Little packette is not nearly enough. Lubricant needs to go on both end of the caliper. This is what I used. Lubricant
