randallb
Feb 10, 2015Explorer
Either the booster is bad, the M/C you installed has a slightly longer ram or the brake pedal linkage is hanging up slightly. If the issue did not exist prior to your brake work then I would pull the M/C, place a slight amount of light putty/playdough on the booster pin and see what happens when you tighten up the M/C. Your primary check should be that the M/C settles on to the booster face with absolutely no resistance. Any resistance guarantees the M/C ram is long or the booster is hanging up. Judging by the age I would probably just replace the booster but first have someone pull the brake pedal up if the M/C does not hit the booster with no resistance.
Randy
Randy
