1969SSCamaro
Mar 01, 2015Explorer
Cool rainy day here, so decided to jackup front end of MH and see if brakes were sticking. Everything appeared to be fine, but I disassembled the linkage to inspect and lube. It was definitely long overdue; grease was gummy/sticky. Unfortunately I am unable to reomve the main piece of linkage that connects the brake-cylinder-actuator and the brake-pedal-arm; gold piece with two brackets to connect linkage to - refer to picture. If the bolt was inserted from the other side it would be no problem; notice the bolt-head sticking out about 3/4". It is hitting the radiator mtg assy. It appears the only way to remove this is to remove the black mtg bracket attached to the frame, which supports the entire master cylinder and brake linkage, but not so easy/simple to remove. Anyone got any ideas or experience here?
