Gjac
Mar 25, 2015Explorer III
I am glad you got your brakes fixed. I spent a small fortune on my front end getting that right. Henderson makes some good replacement parts.Bell crank helped along with idler arm and ball joints. I would add the steer safe if you don't have it already. The other thing I would check is the ride height between the stops on the A arm. They are different for each P-30 chassis but you should have about an 1 3/4 inches. Good luck.
