flash_flood
Aug 26, 2013Explorer
Gene in NE wrote:
flash,flood - I use a "C" clamp and the old disc pad against the piston to push it back into it's housing. You do need to watch the master cylinder. You will be pushing the brake fluid back up into the master and it could overfill and make a mess. :)
I had no problem with pushing the piston back in, it was putting the caliper back on and securing it. I managed to keep the caliper elevated enough to be able to wedge the two piece in and then pound them into place and secure the one bolt. For such a big vehicle it sure seems like a weak way of holding the caliper on compared to the typical 2 bolt style I am failure with. All four calipers have just one little allen head bolt that secure a bracket that wedges the caliper into place.
38,766 PostsLatest Activity: Jan 10, 2026
