wvhurricane
Jul 20, 2018Explorer
Thanks RLS7201! I found this on an old threat on irv2. Good stuff
Posted By: RLS7201 on 11/26/09 11:35am
DAYCO Part # 5060505 {Exceeds OE Specifications}
Fan, Alt. & A.P., w/130 Amp Alt.
GATES Part # K060505 {Automotive V-Ribbed Belt (Standard); K06 13/16" x 51"}
Fan, Alternator and Air Pump; W/130A. Alt.
GATES Part # K060685 {Automotive V-Ribbed Belt (Standard); K06 13/16" x 69
1/8"}
Fan, Air Conditioning and Power Steering
ACDELCO Part # 6K685 {K06 13/16" x 69 1/8" #88932724}
BELT,SERPENTINE FAN, A/C & P/S
GATES Part # 38140 {Belt Drive Tensioner; Thermoplastic Smooth (90mm x 17mm x
32mm) - Flanged / Hydraulic-No}
DAYCO Part # 89221 Belt Tensioner
ACDELCO Part # 1520676 {replaces 88919204 #19190145, 88919204}
TENSIONER,DRV BELT TENSIONER PULLEY
This is the short hose that goes from the oil cooler to the water pump:
GATES Part # 21909 {Molded Coolant Hose; 1 11/16" x 1 25/32" x 3 19/32" Does
Not Contain Spring}
Lower - Pipe To Water Pump
Motorcraft KM4941 Upper Radiator Hose
RECREATIONAL - STRIPPED CHASSIS - F53
Motorcraft KM4969 Lower Radiator Hose
PCV Valve:
STANDARD MOTOR PRODUCTS Part # V326
Thread Type
The transmission filter you need is for a 4x4 460 W/E4OD, Pick up. Just tell
them you need the tall filter (deep pan)for a 4x4.
ACDELCO Part # TF283 {#25174481}
FILTER KIT,A/TRNS FLUID 20 HOLES, DEEP PAN; E4OD TRANS, 4 SPEED
The upper and lower radiator hoses are becoming very hard to find. Most listings
are for the F53 truck and will not fit the F53 motorhome. Different radiator for
each application. Your friendly Ford truck dealer can supply them for approx.
$45.00 ea.
Approx. $25.00 ea. from Motorcraft, through your local parts
supply house.
1/8"}
Not Contain Spring}
PCV Valve:
Thread Type
$45.00 ea.
supply house.
