Yaj
May 09, 2013Explorer
I found the fuse located by the battery when we were on the road and it checked out good, but today I double checked it and yes it is/was good (power in the wire after all connections and fuse) but what gave me the opportunity to clean everything including the battery connections. Everything shiny and properly protected now.
So, I still have no power to the Allison box. I'm going to try to trace backwards from there.
I should be receiving the wiring diagram from Freightliner in the next couple of minutes, so that should help. Freightliner was really nice and tried to be helpful, and offered up the diagram as soon as asked.
I do have a test lamp wired in so that will save a lot of trouble some checking. Easy to hang the light out the window while I was checking around the chassis battery.
Thanks for the phone number and all the helpful suggestions.
Update at 11, or before if/when I find the issue!
