Gjac
Aug 06, 2020Explorer III
That vintage Class A should be less than half of your budget. Maintenance is more important than make or model of an older MH. Check maintenance records, for all fluid changes etc. Exhaust manifold leaks were common in both 460's and 454 engines, headers fixed that issue reducing engine heat and adding about 80 more HP. If you don't mind fixing things it could be a good MH or a money pit if you have to take it to a shop every time something goes wrong.
