Matt_Colie
Aug 06, 2020Explorer II
Vincent,
A very common misconception is that the chassis and engine are the big issues of any class A or C. That is just not the case. Water leakage into the house structure is a much bigger issue. If you see evidence of that, think seriously of not buying. When you have a coach to take care of, get up on the roof regularly and inspect for possible issues.
What you are considering is only a senior RV, but it is still old enough to have the problems that are common to anything that old. At about 15 years, rubber parts start failing. If you have any capability (I do mean just about any), this is all something you can do and the cost of all the material required is usually less than a K$ (less than the new tires it will probably also need). All the rubber parts, just like tires that are dangerous over 8 years old, like fuel, coolant and brake lines. This is also not that tough as the coolants corrosion inhibitors are gone, and the brake fluid probably has high water content and those things should be changed our any way. The rubber fuel lines may not have been alcohol tolerant, they can get porous and that will cause unending grief.
Does this guy know the situation?
Our completely reliable coach is not that far from being 50.
Matt
Matt
