RLS7201
Jun 19, 2022Explorer II
MrWizard wrote:
Water pump is leaking, storage area all wet, and pump blows fuse, it seems water is getting into motor,
Is there a shutoff so i can change pump with out flooding the space i must crawl into,
There is a tank drain valve, at the tank, but that output pipe is broken, and will flood the area if i use it,
From my years around Bounders, I've not seen a shutoff before the pump.
Any chance you have some rubber plugs laying around. Unscrew the inlet fitting and stuff a plug in it quickly.
Maybe Loosen the mounting screws on the old pump and install the inlet fitting on the new pump, quickly. Have towels laying around the pump.
AH! syphon the water out of the gravity fill.
I'll accept that cup of coffee the next time we meet. he he
Richard
