mcphail1701's avatar
mcphail1701
1997 Coachman Catalina Water Heater
Hi All,
I am stumped on an issue with my hot water. When the propane heater is switch on, it runs from hot, cold, hot, cold - never consistently warm. I am not sure what could be wrong. If anyone can point me in the right direction to diagnose this problem, it would be greatly appreciated.
I own a 1997 coachman catalina sport (class C) https://coachmenrv.com/OwnersManuals/14186021.pdf
  • No outdoor shower- I fixed the problem. When you install a new water pump, the pressure needs to be adjusted so that the water flow is consistent. It was not consistent, causing the water to cycle from hot to cold & so on. ??
  • 4x4van's avatar
    4x4van
    Explorer III
    Do you have an outdoor shower? If so, check to make sure that it is turned off at the valves and not just at the shower head.
  • The by pass valve is behind the water heater. You might need to open a drawer or open a cabinet or open an inside storage area to reach behind the water heater. You might need a new thermostat which can be replaced on the outside of the water heater. The thermostat looks like two metal buttons usually one on top of the other.
  • if your not sure? trial an error will help. most times this turns out to be a simple fix .
  • Look at page 28 of the owner's manual for valves and position.
  • Are these the valves under the bedding area? I know that one opens & empties the fresh water, but I do not know what the other two are. They are not labeled.
  • check your by pass valve not closed. cold water is getting into your hot line, a valve not shut ,a mixing valve open etc. a faucet screen clogged and valve open?
