YC_1
Jan 24, 2019Nomad
kenwautoone wrote:
This is common problem with Ford's of this area.80% chance is a bad fuel pump.please use an AC Delco or motorcraft pump.you will not find these most big box auto parts houses.
Ditto: Ditto: Ditto: Has come up often. I had an 89 that acted up for a couple of years off and on until it finally died long enough to diagnose. Acted so like vapor lock. Things like a hot day, running the generator to power the AC, climbing steep hills all seemed to contribute to the symptoms.
The fuel filter along the frame rail is so often neglected or forgotten. At 11 k miles mine was blocked. I suspect that put added strain on the fuel pump.
An inline pump might not draw through a bad fuel pump.
38,780 PostsLatest Activity: Jul 04, 2015
