john_engel
Jun 14, 2018Explorer
MrWizard wrote:
it really helps to know what motorhome model year etcc
sounds like the ignition switch is at the bottom of cable
the cable operated by the key, turms on the switch
sounds like the switch has shorted out , using the cable for ground
The ignition switch is on top of the column where they normally are...using a steel rod actuator. There is something else near the bottom of the column that is heating up.
38,771 PostsLatest Activity: Apr 20, 2026
