DrewE
Mar 04, 2017Explorer III
Shorting the battery directly would not be likely to pop any house circuit breakers or fuses. It might cause a fuse to blow in the circuit between the chassis and house batteries with the isolator.
It is possible that the shorted house battery is damaged. Obviously you need to work out a properly secure battery hold down. A shorting out lead acid battery can lead to all sorts of quite bad things.
